Colgym
Jul 04, 2021Tutor
AX4300 (RAX45) 'your connection is not private' '/untrusted server blocked
I am running with NightHawk AX4300 (model RAX45). About 1 day ago i started seeing several different things which I am not sure of the cause but would like to find the solution. Observations: ...
- Jul 10, 2021
If you factory reset you router this may help as you set things up again.
After factory reset.
1. Make a backup of router configuration.
When you make your 1st changes with perferred SSID and New Admin and Password.
2. Make a backup router confiruration.
Once everthing is setup and working properly.
3. Make a backup rounter configuration
Now this will help in troubleshooting should you have to perform more factory resets
I know it is tedious & reduncant but it can save you a lot of time by just restoring a configuration.
Tips that have helpled me in the past and currently.
Before router firmware upgrade.
-Make a note of the firmware version
-Make a backup router configuration in case you've modified your configuration.
Or have to downgrade back to a previous firmware version
After router firmware upgrade.
Make a back router configuration because your configuration is not running on a new version.
slackrl
Christian_R
Jul 08, 2021NETGEAR Employee Retired
Hello Colgym,
May you check to see if your router is due for a firmware update and check if there is a google chrome update available.
Christian
- ColgymJul 08, 2021Tutor
I checked and router is not wanting a firmware update. Chrome is current.
Is there anything security related that runs on router on an initial install that stops after 90 or 120 days? this was working just fine and no change happened.
