Colgym
Jul 04, 2021Tutor
AX4300 (RAX45) 'your connection is not private' '/untrusted server blocked
I am running with NightHawk AX4300 (model RAX45). About 1 day ago i started seeing several different things which I am not sure of the cause but would like to find the solution. Observations: ...
- Jul 10, 2021
If you factory reset you router this may help as you set things up again.
After factory reset.
1. Make a backup of router configuration.
When you make your 1st changes with perferred SSID and New Admin and Password.
2. Make a backup router confiruration.
Once everthing is setup and working properly.
3. Make a backup rounter configuration
Now this will help in troubleshooting should you have to perform more factory resets
I know it is tedious & reduncant but it can save you a lot of time by just restoring a configuration.
Tips that have helpled me in the past and currently.
Before router firmware upgrade.
-Make a note of the firmware version
-Make a backup router configuration in case you've modified your configuration.
Or have to downgrade back to a previous firmware version
After router firmware upgrade.
Make a back router configuration because your configuration is not running on a new version.
slackrl
