Colgym
Jul 04, 2021Tutor
AX4300 (RAX45) 'your connection is not private' '/untrusted server blocked
I am running with NightHawk AX4300 (model RAX45). About 1 day ago i started seeing several different things which I am not sure of the cause but would like to find the solution. Observations: ...
- Jul 10, 2021
If you factory reset you router this may help as you set things up again.
After factory reset.
1. Make a backup of router configuration.
When you make your 1st changes with perferred SSID and New Admin and Password.
2. Make a backup router confiruration.
Once everthing is setup and working properly.
3. Make a backup rounter configuration
Now this will help in troubleshooting should you have to perform more factory resets
I know it is tedious & reduncant but it can save you a lot of time by just restoring a configuration.
Tips that have helpled me in the past and currently.
Before router firmware upgrade.
-Make a note of the firmware version
-Make a backup router configuration in case you've modified your configuration.
Or have to downgrade back to a previous firmware version
After router firmware upgrade.
Make a back router configuration because your configuration is not running on a new version.
slackrl
slackrl
Jul 10, 2021Luminary
slackrl
Colgym
Jul 10, 2021Tutor
many thanks for the suggestions.
I do not mind going down the path of a factory reset and I will do the backups.
- slackrlJul 10, 2021Luminary
U R Welcome!
Post back and let us know how things turned out.
slackrl
- ColgymJul 12, 2021Tutor
problem went away
maybe the upgrade caused it - not sure
many thanks to you, slackrl, and rest of forum!
with backups - feel better prepared for next firmware upgrade.
Thanks again!!!
- slackrlJul 13, 2021Luminary
U. R. Welcome.
Thaks for posting back.
Glad to hear that things are working well.
When the router is doing good it certainly make life a little easier.
Jesus Loves You
slackrl
