sligade
May 23, 2021Aspirant
Ax4300 with horrible wifi speed
Hello, Just trying to replace fios G3100 internet only (200mbps speed) router with AX4300. fios router is working great, I have 4 Wired connections and 2.4 a wifi enabled. as well 5Ghz wifi. also set...
michaelkenward
May 24, 2021Guru - Experienced User
Neither of those is a Netgear model number. The AX4300 could be RAX45 or RAX50.
sligade wrote:
Just disconnected fios router and plugged in ax4300, connected all my wired connections.
You can't just unplug one thing and replace it with something else and expect everything to go through smoothly. At a minimum you should restart the network.
As this is a router, there is probably a modem sitting in front of it. You need to get the devices to forget any inherited settings. Among other things, that means rebooting the network.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
If that doesn't fix problems, then a reset of the router, and maybe the modem, may be needed.
sligade
May 24, 2021Aspirant
Thanks
I will try these and let you know. BTW it RAX45
I also saw https://www.techlicious.com/tip/how-to-use-your-own-router-for-verizon-fios/comments-/CP3/#:~:text=Click%20on%20My%20Network%20at,click%20Release%20under%20DHCP%20Lease. Tlaking about DHCP release, do you think that is necessary? May be I will add these in your instructions as well..
Thanks
SL
