Deep_logic
Dec 03, 2023Aspirant
AX5300 RING ALARM
I just purchased a AX5300 NIGHTHAWK router a few days' ago. I noticed that the associated products won't have an option for my brand new AX5300. I had an ORBI that is about 5 years old and I thin...
Deep_logic
Dec 04, 2023Aspirant
I looked under the router - it says RAX49. One other thing that was annoying - my laptop was showing it being connected but when I would go to different web pages I would get errors saying "this doesn't support HSTS". I re-connected my old ORBI router and now every page comes up with no errors.
michaelkenward
Dec 04, 2023Guru - Experienced User
I have no idea what that means. But if your laptop is Windows, perhaps that is where you should look for the problem.
It is all too easy to shout "router" whenever you have a problem when you connect to the network. But that misses out several key factors.
How did you connect this laptop to the network? Wifi? Wired?
What browser gave the error? What about other browsers?
Google suggests other places where you could troubleshoot:
this doesn't support HSTS - Google Search
Nothing in there suggests that a router could cause the problem.
