mrosen
Jan 01, 2021Tutor
AX5400 Modem Requirements
I am considering this router but I'm confused as to whether or not I need a modem with a 2.5 Gbps ethernet port. While shopping for cable modems, I see there are modems offering this and those that ...
mrosen
Jan 01, 2021Tutor
Newfiedrool
Jan 01, 2021Virtuoso
That's all you will get so a 2.5 port would not get you anymore than 600Mbps.
I'm guessing you are US where I'm U.K. so I don't know all the various types available but I'm sure if you posted some a helpful person will help out.
- NewfiedroolJan 02, 2021Virtuoso
I'm also bit confused as I'm not sure the router you are looking has 2.5 connection. What's the model you are looking at?
