mrosen
Jan 01, 2021Tutor
AX5400 Modem Requirements
I am considering this router but I'm confused as to whether or not I need a modem with a 2.5 Gbps ethernet port. While shopping for cable modems, I see there are modems offering this and those that ...
Jan 02, 2021Guru - Experienced User
What router are you looking at? AX5400 is a speed.
A 2.5g port is nice if you're isp is supporting >1 gig speeds. Or if you plan on upgrading in the future to those speeds.
But if you have no intention of >1gig speeds, then there isn't much benefit to it.
mrosen
Jan 05, 2021Tutor
Ah, that's confusing. I ended up getting the RAX50 but now I'm going to try out the Orbi RBK752.
Thanks.
