rjgvt
Aug 21, 2024Aspirant
AX5400 RAX50 for Fidium Fiber
New member here. Recently switched from Consolidated Communications slow DSL, 9Mbps/1Mbps to Fidium Fiber 300Mbps/300Mbps at my camp. My camp is 20’ x 20’. Their router is connected to the ONT that t...
michaelkenward
Aug 22, 2024Guru - Experienced User
rjgvt wrote:
We surf the web, stream some on the TV with a Firestick and now some Blink cameras since the upload speed is way more than 2Mbps. I was thinking of getting the Netgear AX5400 RAX50 as it is at a better price point than the AX6000. I read earlier today that Netgear has discontinued remote management. Probably not a deal breaker. I’ll do the setup with a laptop and an ethernet cable when not on the network.
Can't the Fidium device manage those things? As Kitsap says, it is also a router.
Want do you want to do that it can't handle?
To get some ideas for kit that might meet your needs, try this:
Wireless Routers for Home | NETGEAR
Plug in your details and see what comes up.
You may also like to see if you can find instructions on how to disable the router bit of your Adtran 854-6
adtran 854-v6 bridge mode - Google Search
Just another user with time on their hands.
