sterk03
May 29, 2023Aspirant
AX5400 RAX50
Netgear AX5400 RAX50 Some items to be controlled by wifi in your house demand 5g or 2g. During setup which has been a while It seemed that the router picked the network based on what needed control ...
sterk03
May 30, 2023Aspirant
Trying to hook up a wifi light bulb which has an app. It says it will only work on 2G. I sign in with to my router network and password but the bulb will not pair with the app and I have no idea if the network is 5 or 2G and so I am not sure the bulb will seek out a 2G network and the Netgear should see this and sign in.
Best I can describe it. Online you then can change on/off color schedule.
Thanks for your reply.
Sterk03
May 30, 2023Guru - Experienced User
Try disabling Smart Connect on the router.
