Matpeakrock
Aug 14, 2024Follower
AX5400 Router to modem not connecting
I have a older Nighthawk in use right now, I am trying to connect my new AX5400 and will not connect to the ISP modem. (red light is still on) What direction should I look for. Thanks in advance for ...
Aug 14, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Matpeakrock wrote:
I have a older Nighthawk in use right now, I am trying to connect my new AX5400 and will not connect to the ISP modem. (red light is still on) What direction should I look for. Thanks in advance for any sugestions.
