jjjhawk88
Mar 16, 2021Tutor
AX5400 Starts Dropping Wi-Fi During Big Downloads
Hello Netgear Community, I'm hoping to get some help here. I've been trying to figure out a problem that has been plauging my house hold for about 9 months. In short, if both my wife and I are...
Christian_R
Mar 19, 2021NETGEAR Employee Retired
Hello jjjhawk88,
Welcome to the community! Have you had a moment to get in contact with our support team regarding this?
https://www.netgear.com/support/contact.aspx
Christian
jjjhawk88
Mar 25, 2021Tutor
Thanks for the reply Christian_R . I did contact Netgear support when this first started to happen. At that time there was little information to go on, so they required that I make sure it wasn't the ISP and then give them a call back once I had excluded the ISP as the issue. I don't necessarily know how to definitivley do that, but I'm pretty sure my current setup excluded the ISP since anything connected to the router Wi-Fi is shut off but anything connected to my LAN port extender is fine and has no trouble. I may try and give them another call, but I feel like it's a setting that I'm not yet identifying driving the issue. I thought a post here might provide an quicker answer.
Thanks again!
