revenantananias
Aug 08, 2024Aspirant
ax5400 USB3 not working
firmare is 1.1.4.28 the usb3 is not working. of course, I am a month out of the yearly warranty. this is the second time this has happened to me with this same router. are these prone to failure,...
- Aug 11, 2024
I have no idea why, but I wanted to make sure that the laCie hard drive was indeed working before I went through the inexplicable joy of factory resetting the router. My Mac saw it and I was happy with that, I plugged it back into the router before I was about to do the factory reset and was amazed that the usb light on the router turned on. I then checked the network and lo and behold the drive was there.
no sure what that was all about, but I am happy it is over.
thanks.
revenantananias
Aug 09, 2024Aspirant
well, the device is fine, I can plug it into my computer and see it no problem. I will try restarting the router this weekend.
revenantananias
Aug 11, 2024Aspirant
thanks.
