kevin820125100
Feb 09, 2021Aspirant
AX5400 WiFi 6 Router with A7000 adapter
Today I updated my internet to 500/500 fiber internet. The interesting thing is that I used nighthawk app to check speed and it is totally fine. however, I use my PC with A7000 night hawk adapter to...
Feb 09, 2021Guru - Experienced User
when you test through the netgear app, it hosts the test on the router.
when use test on the speedtest app, its hosting on the device you're testing on which means its also testing the wireless signal/strength.
So if you're computer is further away from the router, has interference, testing on the wrong channel (2.4ghz is slow), then you're speeds are going to be lower.
- kevin820125100Feb 09, 2021Aspirant
SO it means there is no way to get 500/500 using wifi?
- plemansFeb 10, 2021Guru - Experienced User
I didn't say that. but there are a lot of variables that impact wireless speeds.
If you're computer is next to the router, there's not much for interference, then you might hit those speeds.
in terms of wireless, 2.4ghz is slow. If its hitting 100mbps, its doing great. 5ghz is the faster network by far. Some devices will hit 500+mbps. But 5ghz signal/speeds drop off faster than 2.4ghz does. And its more sensitive to obstructions like walls/furniture/etc.
How far from the router is the computer?
What are the interior walls made of? (and how many are there)
- kevin820125100Feb 17, 2021AspirantActually it is not too far , like 15 feet , and technically it is no wall between my adapter and router cuz my adapter put beside the door . And i can see my router directly through the doorway .
So that’s why I’m so confusing
