anicaretta3
Dec 09, 2021Aspirant
Ax5400/Rax50 Smb Version Supported
Does anyone know which Smb versions are supported by the RAX50/AX5400? Tech support was unable to provide an answer and I don’t want to end up in the same situation that I currently have with my WNR45...
Dec 10, 2021Guru - Experienced User
You might as a forum moderator and see if they can tell you.
Though from this users post, his RAX80 series seems to be working with Windows 11 and USB storage so this would kind of inidicate SMB version being used would be something other than v1.
- anicaretta3Dec 10, 2021AspirantThat makes sense, hopefully that is the case. I'll post over there and take a look at the other posts, thanks!
