dennisg9987's avatar
dennisg9987
Follower
Jan 17, 2021
AX6 6-stream WiFi Router AX 4300 Model#RAX45
Hi, just installed Nighthawk router and netgear 8 port switch.
Running wired connection to my tv via netgear switch.
Netgear switch replaced older switch. T
rying to connect my roku via wired connection.
Roku set up says I am connected via wired connection to router but not connected to internet.
How do I correct this?
Thanks for any help. Dennisl
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello dennisg9987,
    If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
    https://www.netgear.com/support/contact.aspx
    Christian
