Calico1914
Dec 09, 2020Follower
AX6 nighthawk 5ghz question
Hey everyone, I just recently upgraded my router. I have an AX6 ax5200 Netgear nighthawk router. For some reason if I unplug my router and turn it back on, the 5ghz band doesn’t perform well. It will...
Christian_R
Dec 15, 2020NETGEAR Employee Retired
Hello Calico1914,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
