SchubeTube
Dec 09, 2021Aspirant
AX6 Power Amber LED, No Internet LED
Wife disconnected the modem on accident and and after reconnecting, the Nighthawk X6 RAX50 wifi can't be found. The Power LED comes on blue and turns Amber. Occasionally blinks and flickers to blue, b...
Dec 09, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router?
Turn off and unplug modem.
Be sure the WAN port on the RAX is connected to the modem port.
SchubeTube
According to the app, the firmware is 1.0.4.100.
Our internet is through Insight/Spectrum, but we use our own Arris modem SB6183.
I have tried power off sequence for both modem and router, in delayed 2 min reconnect.
If it helps, I should also note we also have an ASUS router that is hubbed off of a Giga Switch that reconnected after a hard reset. But the Nughthawk baffles me.
- FURRYe38Dec 10, 2021Guru - Experienced User
So how is the modem and NG router connected? The RAX router needs to be connected directly behind the ISP modem. There should be no LAN switch in between these two devices.
- michaelkenwardDec 10, 2021Guru - Experienced User
SchubeTube wrote:
According to the app, the firmware is 1.0.4.100.The app is not a reliable test of the status of the firmware. It can miss recent updates.
The best way to check if it is the latest is to look on the support pages.
Visit the support pages:
Support | NETGEAR
Feed in your model number and that page will have a library of firmware.
Look for the model number on the label on the device.
Begin with the Quick Start/Installation Guide.
Check the section in the manual on updating the firmware.
If it helps, I should also note we also have an ASUS router that is hubbed off of a Giga Switch that reconnected after a hard reset. But the Nughthawk baffles me.You have two routers on your network?
If so, that's asking for trouble.
No surprise that one router connects but the others falls over.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
