Joenorr
Oct 24, 2020Follower
ax6 what percent decrease in speed from Ethernet to wireless is acceptable at close range
At close range 10 feet. The wireless drops to 16 from 110 mbps with eithernet connection. At other ranges phones and laptops are similar speeds. What percent from 110 mbps is accaptable. THANKS this is model ax4300 Highthawk from Cosco.
1 Reply
- Christian_RNETGEAR Employee Retired
Hi Joenorr,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
