dcphillips
Feb 08, 2022Follower
AX6000 WiFi 6, 10Gbps Max download (CAX80) / AT&T Fiber BGW 320
I just changed from Spectrum cable to AT&T Fiber 1000 (940Mbps download, 880Mpbs upload). AT&T installs a combination ONT/Gateway (BGW 320) in a single box and forces you to use their router. The off...
Feb 08, 2022Guru - Experienced User
You can't.
the CAX80 has a modem only mode but not a router only mode.
so when it detects no modem connection, won't work.
some of the older ones you could force into a "access point" type of setup but this one you can't.
Sorry.
