kdogfister
Nov 23, 2020Aspirant
AX6600 and Mitel 5330 stuck in DHCP discovery
I have a brand new AX6600 that is up and running great. Unfortunately, my Mitel 5330 phone gets stuck in discovery mode when connected to it. Have a non-router modem from the cable company and the phone works fine when plugged directly into the modem.
What am I missing that is causing the IP phone to get stuck?
- Christian_RNETGEAR Employee Retired
Hello kdogfister,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
- kdogfisterAspirantThank you, I have. Figured I’d check here as well to see if this was a common issue.
