aoz
Aug 29, 2022Tutor
ax6600 mounting, best position to do this
what is the best orientation to wall mount the ax6600? with the wire ports facing UP? or with the wire ports facing DOWN? or the wire ports facing sideways? if i mount them DOWN, it easier fo...
michaelkenward
Aug 29, 2022Guru - Experienced User
plemans wrote:
What actual router do you have? AX6600 is the spec.
RAX70?
aoz
Aug 30, 2022Tutor
to all, to clarify, model is the RAX70
nick
