aoz
Aug 29, 2022Tutor
ax6600 mounting, best position to do this
what is the best orientation to wall mount the ax6600? with the wire ports facing UP? or with the wire ports facing DOWN? or the wire ports facing sideways? if i mount them DOWN, it easier fo...
Aug 31, 2022Guru - Experienced User
If you look at the fcc photos: 20100478 NIGHTHAWK AX8 8-Stream Tri-Band AX WiFi Router Teardown Internal Photos P20070219-FCC-2_EUT Photo_int_rev Netgear orporated (fccid.io)
they're omnidirectional antenna's. So you should be able to place them how you want
- aozAug 31, 2022Tutor
thanks to everyone for assistance !
