maek314
Mar 29, 2021Follower
AX6600 (RAX70) keeps losing internet
Hello. First-time poster. I have seen this issue crop up as I've been researching this and it appears that this problem has been fairly widespread WITHOUT a solution. I have both an Orbi ...
deepsouth06
Apr 07, 2021Tutor
Any luck on getting this fixed. Just bought mine yesterday and all day today my internet has been dropping in and out, espcecially when both my wife and I are on meetings.
centauratlas
Jul 23, 2021Tutor
I see the same thing. I was hoping there was an update to fix the issue, but it has been going on for months.
- Sberendt1Jul 25, 2021InitiateThe only thing I have found is to turn off Smart Connect and just have separate wifi connections. This thing does not work well AT ALL with older wifi devices. After I did that, everything stays connected. But I must say that I still don't have as good of performance as I did with my previous Nighthawk...bums me out. Connect you older wifi devices to the 2.4ghz wifi and they should stay connected afterwards.
- centauratlasJul 25, 2021Tutor
Thanks for the suggestion - I do have that off. I am going to try turning off the 20/40 MHz Coexistence. :-)
- j911gJul 29, 2021Tutor
Any luck fixing this? Mine is having a similar issue, was thinking about maybe rolling back the firmware.
