maek314
Mar 29, 2021Follower
AX6600 (RAX70) keeps losing internet
Hello. First-time poster. I have seen this issue crop up as I've been researching this and it appears that this problem has been fairly widespread WITHOUT a solution. I have both an Orbi ...
centauratlas
Jul 30, 2021Tutor
Thanks. If I figure anything out I’ll follow up also.
j911g
Aug 28, 2021Tutor
Just wanted to give you an update that I gave up, kept having the issue and didn't want to go through the RMA process. I had bought the router from Costco so I just ended up returning it and replacing it with an Eero setup, no issues whatsover with the new Eero routers. Best of luck!
