Badbart
Aug 03, 2023Follower
Ax6600 Rax70 with cisco 5320 ip hone issues
I am stumped, and I need some help to understand how to further diagnose and fix the problem. AX6600 WiFi Router (RAX70), CM1200 cable modem. Xfinity internet at 450mbps I'm trying to setup my c...
Kitsap
Aug 03, 2023Master
SIP ALG has been known to cause problems with VOIP phones. By default it is enabled on Netgear routers. Go to Advanced -> Setup -> WAN Setup, toward the bottom you should see a checkbox to disable SIP ALG. You may have to reboot your router.
SIP ALG is a good start point for a web search regarding configuration of routers to support VOIP phones.
