Jodi-Coghill
Jul 19, 2023Aspirant
AX6600 router and want to connect 2 ethernet cables to 2 different computers
I want to connect 2 of my computer towers to the one router, but only one will work. Any suggestions how to get both of them connected? thanks,
Jul 19, 2023Guru - Experienced User
What model# router do you have? RAX###?
Check ethernet connections and configurations on PCs. Update ethernet drivers on the PCs.
CAT6 LAN cable is recommended.
Check LAN ports in back of the router, try all LAN ports.
