Jodi-Coghill
Jul 19, 2023Aspirant
AX6600 router and want to connect 2 ethernet cables to 2 different computers
I want to connect 2 of my computer towers to the one router, but only one will work. Any suggestions how to get both of them connected? thanks,
michaelkenward
Jul 19, 2023Guru - Experienced User
Tell us more.
As well as details of the Netgear router, the model number, how are you trying to connect these PCs? Wired to the Ethernet ports on the router?
What happens on the tower that won't connect? Any error messages?
The more detail you can provide, the quicker we can offer suggestions.
Jodi-Coghill
The model is AX6600 and it is in the subject line. I want to connect 2 ethernet cables to 2 computers.
One connects but the other does not
- FURRYe38Jul 19, 2023Guru - Experienced User
What model# router do you have? RAX###?
- Jodi-CoghillJul 19, 2023Aspirant
RAX70-100NAS
What FW version is loaded?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Be sure to check the PCs ethernet networking configuration. Should be configured for Auto-Obtain Networking. Contact the mfr of these PCs for additional help and information regarding there product. If one PC works and the other doesn't, the other PC needs to be reviewed.
- michaelkenwardJul 19, 2023Guru - Experienced User
We still don't know what happens when you try to connect the second computer.
There are usually error messages or prompts of some sort when you try to plug it in.
- Jodi-CoghillJul 19, 2023AspirantIt does not have internet connection.
Jodi-Coghill wrote:
It does not have internet connection.Again, that's a bit thin on useful details.
The PCs can see each other and it is just the Internet on one that doesn't work?
If this is a Windows PC, which version and what does it say in Settings > Network & Internet?
Have you tried the network troubleshooter in Windows?
