Jodi-Coghill
Jul 19, 2023Aspirant
AX6600 router and want to connect 2 ethernet cables to 2 different computers
I want to connect 2 of my computer towers to the one router, but only one will work. Any suggestions how to get both of them connected? thanks,
Jul 19, 2023Guru - Experienced User
What FW version is loaded?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Be sure to check the PCs ethernet networking configuration. Should be configured for Auto-Obtain Networking. Contact the mfr of these PCs for additional help and information regarding there product. If one PC works and the other doesn't, the other PC needs to be reviewed.
Jodi-Coghill
thank you - I will try it
