gwbaker
Aug 14, 2019Guide
AX8 Anyone have their AX8 factory reset itslef loosing all settings?
So I came home yesterday and all 40 of my devices had lost internet connectivity. My netgear CM1100 lights showed connectivity, so did the AX8's lights ??? Upon checking I found that my AX8 rout...
dbo_cowboy
Aug 17, 2019Aspirant
I used to have my old router on a UPS but this one is not. The AX8 has it happen everytime the power goes out. It happened today during a thunderstorm and it even happened once when I just moved it (without unplugging it). I am very confident I didn't hit press the on/off button and nothing came unhooked. It's as if the router has no on-board memory.
gwbaker
Aug 19, 2019Guide
Support reached out today, but was not able to do anything.
When the agent called I advised that I had manually restored all my settings and the router was presently working. He said okay, thanks and closed the case.
Kinda what I figured. My experience with line level tech support is their job is to get you back up and running. They are usually not prepared or able to figure out why something happened, just to get it working again. I understand their function and trying to figure out why something happened without having the router in their posession is nearly impossible. I have pulled the plug once to see if a "power failure" was causing it. The one time I tried it, it did not reset. So, not sure what is going on and likely will not be able to figure it out.
I guess I will just have to wait and see and decide if the reliability is good enough to depend on. Not sure yet.
