exSMile
Feb 24, 2022Aspirant
AX8 power supply idle voltage.
Has anyone measured the idle voltage at the output of the power supply AD2003F10 of the AX8 router with a voltmeter?
- Mar 01, 2022
I did some testing with the 19V adapter, and it holds stable at 19V, it seems like they may be using a power supply that has a sense line connected to the output and likely adjusts voltages as needed to maintain a consistent output.
In cases like this, in order to determine the true voltage input range, you would need to find out which type of DC to DC converter they are using on the 19V rail, and see what their datasheet shows as the input range.
exSMile
Feb 25, 2022Aspirant
It's true.
But I want to know.
Feb 26, 2022Guru - Experienced User
You'd have to open up the router and use a volt meter and take readings at the solder points here the power jack is connected at the router board. Or tap in to the power supply wire.
- exSMileFeb 27, 2022Aspirant
Thank you for answer.
I haven't got original power supply for that.
- FURRYe38Mar 01, 2022Guru - Experienced User
Ya you'd need to get a OEM stock power supply to get a base line.
- Razor512Mar 01, 2022Prodigy
