ehowton
May 28, 2021Follower
AX8 (RAX75) Doesn't show forwarded ports on the Port Forwarding screen
Howdy; I cannot display the forwarded ports on the port forwarding screen, which makes it impossible to edit/delete them. Is there a setting I need to set somewhere to VIEW the forwarded ports? ...
Christian_R
Jun 02, 2021NETGEAR Employee Retired
Hello ehowton,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
