Blkromeo
Nov 06, 2019Tutor
Ax80 & Xbox live
Just got the new Ax80 and I've been having Xbox live/party connection issues on Xbox one. When people join the party, I get disconnected and/or my router resets. In 3 days I have tried numerous solut...
Raidwkr
Nov 07, 2019Initiate
I had similar problems. It works more smoothly with the ethernet. Still have hiccups though. The router costs way too much for this to be happening to us gamers. Netgear's product description gives the impression that you just have to connect and the router will handle everything faster than you can believe.
Blkromeo
Nov 07, 2019Tutor
It still does it with ethernet too. I spent 53 min on the phone tonite waiting for tech support before I hung up and tried to fix it again on my own. I factory reset, cancelled the update to the latest firmware and then assigned a static ip with port forwarding. Haven't had an issue yet (knock on wood) , but it's worked before then gone all haywire the next day So we'll see what happens.
- RaidwkrNov 07, 2019InitiateYes, I do believe the firmware updates have fixed some issues and created new ones. I bought the RAX80 in February and just had it RMAd last month e because it kept losing its configuration every day. At random, it would reset to factory settings.
Anyway, hopefully you resolved the situation.
