Blkromeo
Nov 06, 2019Tutor
Ax80 & Xbox live
Just got the new Ax80 and I've been having Xbox live/party connection issues on Xbox one. When people join the party, I get disconnected and/or my router resets. In 3 days I have tried numerous solut...
Blkromeo
Nov 07, 2019Tutor
It still does it with ethernet too. I spent 53 min on the phone tonite waiting for tech support before I hung up and tried to fix it again on my own. I factory reset, cancelled the update to the latest firmware and then assigned a static ip with port forwarding. Haven't had an issue yet (knock on wood) , but it's worked before then gone all haywire the next day So we'll see what happens.
Raidwkr
Nov 07, 2019Initiate
Yes, I do believe the firmware updates have fixed some issues and created new ones. I bought the RAX80 in February and just had it RMAd last month e because it kept losing its configuration every day. At random, it would reset to factory settings.
Anyway, hopefully you resolved the situation.
