FlaBouy
Mar 20, 2021Aspirant
AX80 connection issues
My R9000 went down a few weeks ago and Netgear sent me a remanufactured AX80 replacement.We won't go back through all of the issues that caused, but I have found work arounds for nearly all of the ot...
FlaBouy
Mar 21, 2021Aspirant
Modem is an Arrix SB8200.
Firmware is latest V1.0.3.102_1.0.48 that was manually uploaded after the latest .50 firmware was buggy. Modem rebooted after firmware upgrade.
Network and internet connectivity works fine when Archer A7 router is swapped in place of the AX80.
Mar 21, 2021Guru - Experienced User
After the firmware change did you attempt a factory reset?
Also the SB8200 has 2x ethernet ports but only 1 is usable for the average user. Make sure only 1 device is connected
- FlaBouyMar 22, 2021Aspirant
Yes, only one WAN port is connected on the SB8200. And yes, I have booted, reset, and reconnected this router by every means known to man over the last two weeks. Netgear does not respond to the support tickets, nor explain why I was sent a remanufactured AX80 to replace the original R9000 I bought. I am done with Netgear. My next boot will be any product with the Netgear logo out of my network. I got fed up yesterday and ordered a new tri-band wifi6. Routers should not be this hard, especially when customer support is non-existant. Thanks for you suggestions my friend. Netgear has burnt this bridge.
