SB007
Jan 11, 2023Follower
AXE7300 Router with Nighthawk 32 x 8 DOCSIS 3.1 Cable Modem
My current setup is the Nighthawk 32 x 8 DOCSIS 3.1 Cable Modem with a Nighthawk AC2300 Dual-Band Wi-Fi 5 Router. This is providing about 560 - 590 mbps. My internet provider upgraded me to 1000 ...
Jan 11, 2023Guru - Experienced User
What speeds do you see with a PC ethernet connected to the back of the modem with out any router in the middile?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
