napo504
Aug 16, 2024Follower
AXE7800 2.4 band is not working
2.4 is not working, allways connected without internet, but 5G band works fine, also I realized that 2.4 bands if I open a VPN. I reseted it 2 times to factory configuration, works a few minutes fine, but againg does not serve internet.
1 Reply
Is Smart Connect enabled or disabled?
Does the 2.4Ghz work with out a VPN?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz
Any Wifi Neighbors near by? If so, how many?Does the top of the router feel warm or hot?
Might try a USB fan under the router...
