KqunKqpar
Nov 20, 2024Tutor
bad bandwith distribution
Hi With QoS and priotiy hight or without QoS my laptop on wifi never got more then 30 mbps (when im lucky) out of my 500. My wired laptop got it all when i test the internet connection, never ha...
KqunKqpar
Nov 20, 2024Tutor
1. what router do you have? Nighthawk RAX50v2
2. what band are you connected to? 2.4ghz or 5ghz? both behave the same way
3. QoS isn't recommended at speeds over 250mbps. so if you have 600mbps, disable qos yes i know but i tried it anyway in case it would help
4. what firmware is on the router? Firmware Version V1.1.4.28_2.1.26
5 and 6 are you serious? if you are it should have a warnin on the box : Check you laptop chipset and your modem chipset before buying this product it just work on specific ones!
5 Arris
6 Realtek RTL8852AE WiFi 6 802.11ax PCIe Adapter
Nov 20, 2024Guru - Experienced User
Always serious about these questions. Details are what let us help you. You wouldn't tell a mechanic when they ask you what motor you have, "it's a Ford". Is it gas? Diesel? 4/6/8 cylinder? Size? etc.
Details are key when helping on a forum. We're not trying to be mean but we need to know your setup to provide decent feedback.
- KqunKqparNov 20, 2024Tutor
i see what you mean!! i tested my cell was at 60 but after that it was really slow, it was slow for hours before coming back to 60 (like between 1 and 5) Anyway my point is i dont want the router to decide for me what my differents device needs!! My cell phone will never need more then 10 my TV more then 50 etc... and i want to be sure to have a min with my two laptop. Was able to do that with router from early 2000... Sorry but it s not personal to netgear i m just not surprise that the router do not an "intelligent " job to dispatch my bandwith. It s just non sense that my wired laptop is always at the top downlaod and top uplaod while my wifi laptop (wich ever one it is) struggle to have 30 and my phone have 60 ...
- DarrenMNov 21, 2024Sr. NETGEAR Moderator
Do you happen to have a really old device, like a DVD player or old laptop, that is connected to the Wi-Fi network and could be slowing down the Wi-Fi for everything?
DarrenM
