goldener444
Jan 28, 2022Tutor
Bad Zoom Quality
Hi experts, I have been using RBK53 which works alright with a fair Zoom quality. Recently I upgraded it to RBK852 then the Zoom voice quality dropped seriously (voice lagging). However, the quality w...
Jan 28, 2022Guru - Experienced User
What firmware is the new router and satellites on?
Have you noticed if the device with issues is connected to the router or the satellite?
- goldener444Jan 28, 2022Tutor
Both are updated to 4.6.3.16.
- plemansJan 28, 2022Guru - Experienced User
might try this version.
New - RBR850 / RBS850 Firmware Version v4.6.7.5 Re... - NETGEAR Communities
And I did try Zoom on laptop and iPad. Also connected to router and satellite at different locations. Results were the same with lagging / missing voice at Zoom. When I switch back to old router , it then returned to the fair quality level.
- Razor512Jan 28, 2022Prodigy
Are you able to try using zoom with a wired connection? This will halep determine if it is a weid bug with a specific WiFi adapter or if it is something else impacting the overall WAN connectivity.
Sorry, typos and no edit button.
Wanted to also ask if speedtest results are similar to the wired connection. Some WiFi issues can lead to realtime communication issues that may not be present on streaming services like netflix which will buffer a minute or 2 worth of video.
