goldener444
Jan 28, 2022Tutor
Bad Zoom Quality
Hi experts, I have been using RBK53 which works alright with a fair Zoom quality. Recently I upgraded it to RBK852 then the Zoom voice quality dropped seriously (voice lagging). However, the quality w...
Jan 28, 2022Guru - Experienced User
What firmware is the new router and satellites on?
Have you noticed if the device with issues is connected to the router or the satellite?
goldener444
Jan 28, 2022Tutor
Both are updated to 4.6.3.16.
- plemansJan 28, 2022Guru - Experienced User
might try this version.
New - RBR850 / RBS850 Firmware Version v4.6.7.5 Re... - NETGEAR Communities
