Retired_Member
Aug 29, 2021Barrage of DoS attacks from legitimate sources
After buying and switching to an new Router, we have constant DOS attacks from our supposed service provider aswell as Google, Github and our service provider, with the same 4 IP addresses every that...
DexterJB
Sep 27, 2021NETGEAR Moderator
Hi Retired_Member, which model and firmware version is your NETEGAR device?
Retired_Member
Sep 28, 2021
DexterJB wrote:Hi Retired_Member, which model and firmware version is your NETEGAR device?
RAX50, Firmware Version V1.0.2.82_2.0.50
- DarrenMSep 29, 2021Sr. NETGEAR Moderator
They could be false positives are the DOS attacks causing any performance issues?
DarrenM
- Retired_MemberSep 29, 2021
They are most certainly false positives, I was just wondering if there was an way to at the very least minimize the frequency of them, as this didnt happen with our last R7000 router.
- Razor512Sep 29, 2021Prodigy
It is not that they didn't happen with the old router, it is that the router just ignored or simply couldnt identify them.
Identifying an attack can be difficult apart from the obvious, e.g., if an IP is flooding you (saturating the WAN connection) with unrequested traffic then it will clearly be able to tell that a DOS attack is happening.
There is no way to make it 100% acurate since there is no way to tell since there is no way to tell the intent behind the traffic, thus they tend to air on the side of mistrust, especially if something happens like an IP that you did not initiate any communication with, is trying to send SNMP traffic to you.
The router will drop the unrequested traffic anyway in both cases, but the newer router be able to identify the type of traffic and estimate if it could have been malicious or not.
A good way to understand it, is to think of the term used in podcasts such as Security Now; the term is Internet Background Radiation.
Basically tons of unrequested traffic from the various botnets, milions of infected PCs, even some ancient windows 98 systems that are still plugged in someway and is trying to spread the malware that it was infected with, where they simply scan the entire IP range endlessly and try to find vulnerable syastems.
