pacumming1
Aug 21, 2023Aspirant
Beamforming and Mu-Mimo and any suggestions for best settings for RAX50 please?
Beamforming and Mu-Mimo and any suggestions for best settings for RAX50 please? Saw this link for Orbi and I am sure it applies to RAX50 as well since I read a related thread as well. https://co...
pacumming
I mentioned I had a router and then I had also an access point. I never said I was keeping another router and going to have a double NAT. So thank you for the reply, but it doesn’t actually assist me. I have a standard router not co
part of a separate cable modem combo. I mentioned I had a router and then I had also an access point. I never said I was keeping another router and going to have a double NAT. So thank you for the reply, but it doesn’t actually assist me. I have a stan ISP WIFI router completely separate from ISP cable modem. And a router configured properly as an access point connected to the router. That’s OK I will figure ask another source about any possible buugy firmware which I believe by reading this does not from prior versions and corrected. Take care
Aug 21, 2023Guru - Experienced User
You'll need to update FW then.
Good Luck.
