stanfrench
Mar 04, 2021Luminary
Benefits of WiFi 6 with older devices
I run around 30+ wifi devices at any time in my home. These devices range from things like smart TV's, Amazon Fire TV's, wifi A/V Amps, smart home devices (thermostat, sprinkler system, cameras, lights), etc. I have a cable gigabit internet signal coming into a Netgear Nighthawk X10 (R9000) router. My home is about 3,000 sqft and I have 2 wifi extenders on the system. I am now experiencing quite a bit of device buffering and connectivity issues (device drop-outs, signal loss). Would the RAX200 provide a more stable network for me? Or are the benefits of the Wifi 6 coming when you also have Wifi 6 devices? Before I shell out $550 for the router, I'd like some thoughts on if I will even notice any improvement. Thanks in advance for any advice.
If you're already using extenders (you didn't say which ones), a mesh system might be a better option. That way you have seamless coverage with a system designed for it.
- stanfrenchLuminary
Thank you. I'm running a Netgear WN3000RP and EX7500 as extenders.
If you just use the R9000 and the EX7500, how does it work?
What is your home made of for materials? certain materials block wifi better than others.
I've got just over 3200sqft and can cover my home with a router and extender. I do tend to use mesh systems as I prefer that route but I'm currently using just a router/extender setup for testing.
