jajaxxon
Dec 18, 2023Aspirant
Best router for Cox Fiber
 I have a 5 year old RAX80 that is giving me issues - what do you all recommend for a gigabit fiber connection (Cox Gigablast).   tried a TP-link router :>(( and can't get ti working, so hope to get a...
- Dec 20, 2023
Smart Connect caused 5g to disappear from our devices, but I have learned how it works, so OK with it
Upgrading today to a new RAX120 to get better coverage
Thx for the help, all
Dec 18, 2023Guru - Experienced User
Any router should work with any ISP service. Most routers from 5+ years ago are 1Gb supporting.
If your having problems with two different branded routers, then something maybe wrong or not working right up stream from the router.
What issues is the RAX80 giving you? Details are important here.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Armor, Smart Parental Controls or Circle, Traffic Meter.
Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
- jajaxxonDec 19, 2023Aspirant
I fixed my problem, thanks for all the replies
