toflyformywifi's avatar
Feb 22, 2021
Beta firmware for rax200
Looking to get access to beta firmware I consistently have issues with wifi dropping. I am working with support but hoping to test firmware.
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello toflyformywifi,
    If you're already in contact with support, I would recommend asking them if they have a trial/beta firmware available for the RAX200.
    Christian
  • I am having an issue with router disconnecting from network and then I can’t access it until I reboot it. Still under warranty. Do I need it exchanged?
    Christian_R
    Hi Dparker1968,
    I would suggest reaching out to our support team to look into your issue further.
    Christian
