Sischka
Sep 18, 2025Aspirant
Blockall new devices - also Guest Network?
I block all new devices, because I have no security PW, I allow only definded MAC Adresses. As it looks, also the guests with a PW could not access to the Network. Have anybody the same situation?
Sep 18, 2025Guru - Experienced User
What NG product and model # are you referring too?
IF a router, have you looked at the access controls on the routers web page?
Guest Network devices can't be controlled.
NG doesn't have controls that are defined by MAC addresses.
