Jepm
Jul 19, 2021Aspirant
Blocked Sites still accessible by devices
Router: 4-Stream AX1800 WiFi 6 Router (RAX10) I have blocked some sites under a profile that has multiple devices. The sites were blocked correctly whenever an attempt to access them was made howeve...
Christian_R
Jul 21, 2021NETGEAR Employee Retired
Hello Jepm,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
- schumakuJul 22, 2021Guru - Experienced User
Talking of Netgear Armor and it's App based config, or mixing with the locally configured "Use keywords to block Internet sites" under ADVANCED > Security > Block Sites?
