KADRAK
Aug 06, 2020Aspirant
Blue and amber lights do not come on at all
The white light flashes during setup or sync. However, the blue and amber lights never show. The satellite shows a blue light or amber as appropriate. The Nighthawk router seems to be working well connected (bridged) to a TP-LINK N600 modem/router used as modem.
Can I fix it? Should I exchange it (involves taking down the network, taking it to be checked at vendor, and reset up with a replacement!)?
- Christian_RNETGEAR Employee Retired
Hi KADRAK,
May you let us know what router model you're referring to.
Thanks,
Christian
- KADRAKAspirant
DUAL BAND WIRELESS MESH SYSTEM (MK62-100UKS)
KADRAK,
Please refer to page 9 of the user manual for the router LED behavior. What is the current status of the router LED?
https://www.downloads.netgear.com/files/GDC/MK62/MK62_UM_EN.pdf
Christian
