KADRAK
Aug 06, 2020Aspirant
Blue and amber lights do not come on at all
The white light flashes during setup or sync. However, the blue and amber lights never show. The satellite shows a blue light or amber as appropriate. The Nighthawk router seems to be working well ...
Christian_R
Aug 19, 2020NETGEAR Employee Retired
KADRAK,
Please refer to page 9 of the user manual for the router LED behavior. What is the current status of the router LED?
https://www.downloads.netgear.com/files/GDC/MK62/MK62_UM_EN.pdf
Christian
KADRAK
Aug 26, 2020Aspirant
It's the same as before ......only the white light functions at all and it functions properly. I have informed the importer and have 2 years to decided whether to request service. Since the router is functioning as expected otherwise, I will probably leave it unless another problem arises. Thank you.
