lin9406
Nov 29, 2021Follower
Bought 3 Netgear routers, only the oldest one function properly, will move on to other manufactures
Used to own a Nighthawk from 2015, worked well, everything worked properly.
Bought a RAX10 last years was working fine, but started dropping connection very frequently. Like at least twice a time, constantly being disconnected from the game server was really some amazing experience.
I made the foolish decision to give Netgear another chance and bought the RAX50, QoS does not even work out of the box, device priorities never save no matter how many times I click apply, or reboot, or rest. Super wonderful experience, the products getting worse and worse with every release, just going to return the overpriced garbage and move on.
1 Reply
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
