sainyi
May 27, 2020Follower
bought the used RAX200 AX11000 from amazon and unable to connect my internet
how can i connect my router?
RajaDaja
May 27, 2020Luminary
What is exactly happening. "Unable to connect to the internet"
Did you do a factory reset if you haven't. I would do that first. There is a pin hold on the back. Press in for 20 sec and release.
Use web browser to get into your router settings by typing in : routerlogin.com or routerlogin.net. Sometimes it's the browser fault so try a different browser if the router login page fails to load.
Make sure you got your cables connected correctly. Coax > Modem > WAN port of Router. Don't use the Night Hawk APP.
This should bring you to the welcome screen and you set up your router
michaelkenward
May 28, 2020Guru - Experienced User
In addition to the sound advice from RajaDaja you could tell us what modem you have in front of this router.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
